A version that looks closer to the Jolly Wrencher (but not identical). Instead of pads on the back it has holes for alligator clips/banana plugs/sewing.
OSHPark board here: https://oshpark.com/shared_projects/TnMcb1Nm
welp now I'm gonna have to order a ton of these! I'll be sure to link everyone here!!
make sure to check the next log, it's a bit nicer
Nice! Would look even nicer to have the silkscreen rounded around the wrenches' pads, though. Instead of rectangular...
Well, wrenches with round holes don't work very well. I could make the copper around the holes rectangular, though, if that helps.
Or hexagon pads - you can play with stop masks to get different shapes
You're totall right here. I just looked at it with my "aesthetic eye" :)
Hex, like K.C Lee wrote, would be good as well
The other one was cuter. This one is awesomer.
Thanks. I think I will play with it some more.
