Hackaday Logo
A project log for Skull
Skull-shaped CircuitPython board.
dehipudeʃhipu • 08/02/2018 at 03:34•8 Comments
A version that looks closer to the Jolly Wrencher (but not identical). Instead of pads on the back it has holes for alligator clips/banana plugs/sewing.
OSHPark board here: https://oshpark.com/shared_projects/TnMcb1Nm
AVR wrote 08/02/2018 at 12:09 • point
welp now I'm gonna have to order a ton of these! I'll be sure to link everyone here!!
deʃhipu wrote 08/02/2018 at 12:15 • point
make sure to check the next log, it's a bit nicer
Jan wrote 08/02/2018 at 10:13 • point
Nice! Would look even nicer to have the silkscreen rounded around the wrenches' pads, though. Instead of rectangular...
deʃhipu wrote 08/02/2018 at 10:42 • point
Well, wrenches with round holes don't work very well. I could make the copper around the holes rectangular, though, if that helps.
K.C. Lee wrote 08/02/2018 at 10:52 • point
Or hexagon pads - you can play with stop masks to get different shapes
Jan wrote 08/02/2018 at 16:53 • point
You're totall right here. I just looked at it with my "aesthetic eye" :)
Hex, like K.C Lee wrote, would be good as well
Elliot Williams wrote 08/02/2018 at 09:06 • point
The other one was cuter.  This one is awesomer.
deʃhipu wrote 08/02/2018 at 10:43 • point
Thanks. I think I will play with it some more.
