The thinnest Magnetic Actuator!
Gerber.rarRAR Archive - 419.09 kB - 07/31/2018 at 23:53 |
A few days ago, I released a new version of my flexible PCB actuator! You can now purchase it for just €2.00, the open source files are also available on my website - www.flexar.io
How small can my Flexible PCB Actuator get? This is the question I tried answering in this video! I first discuss how we can get it smaller and the compromises involved. Then I measured the specifications of each prototype and tested the actuators in different applications.
A PCB can be considered as 'flexible' when its thickness is under 0.3mm. But how can this extra thickness effect the behavior of my flexible PCB Magnetic Actuators?
In the bellow test video I compared the electrical parameters of the coils and also the bending capabilities of both 0.13mm and 0.3mm thick PCBs!
My Flexible PCB Actuator is finally available on tindie.com!
https://www.tindie.com/products/Microbots/flexible-pcb-actuator/
Just received the new flexible PCB actuators! I'll be selling some of these on Tindie! I'll just have to find some time to set up my store! So far I have only selected the name Microbots
Designed a new single coil Flex PCB Actuator! I'm planning to use this as a tiny flap/fin. It the same number of turns as my previous 12 coil pcb.
This video shows the different type of soft actuator prototypes I have managed to build with my flexible PCB. These include flaps, fins and a very weak robotic muscle with a magnetic bone structure.
It also shows a glimpse of a robotic fish prototype that I'm started working on.
Fantastic! How about a swimming motion (like the Festo cuttlefish) by rippling that PCB up and down a "spine" and having fins down the side which follow the motion, transferring it to the fluid?
I also wonder if you can put two PCBs together and mechanically couple them for increased force.
Final thought - how about switching fluid flow with a valve made from this?
Hi! I have already done some experimentation on ferrofluid and pcb coils - https://youtu.be/18ib3ojORBw
It certainly possible, if i add a ferrite core and find an easy way to make a pocket/valve.
Regarding the fish, have you seen the end of the video? That's exactly what I had in mind 🙂
With a row of magnets underneath the strip, pull coil 1, push coil 2 and 3, pull coil 4. This will bend your strip like an omega. Release coils 1-3 and you have forwarded your strip by 1 coil, caterpillar way.
