0.13mm vs 0.3mm thick Flexible PCB Coils
A project log for Flexible PCB Actuator
The thinnest Magnetic Actuator!
carl-bugejaCarl Bugeja • 04/07/2019 at 20:14•0 Comments
A PCB can be considered as 'flexible' when its thickness is under 0.3mm. But how can this extra thickness effect the behavior of my flexible PCB Magnetic Actuators?
In the bellow test video I compared the electrical parameters of the coils and also the bending capabilities of both 0.13mm and 0.3mm thick PCBs!
