Z80-MBC2 User Manual - D081023-R280424.pdf
Adobe Portable Document Format -
11.66 MB -
04/28/2024 at 15:52
Preview
SD-S220718-R290823-v2.zip
The content of the microSD needed to run CP/M 2.2, CP/M 3.0, QP/M 2.71, UCSD Pascal, Collapse OS and Fuzix with IOS S220718-R290823 (More info in the Changelog.txt file inside)
Zip Archive -
5.81 MB -
10/06/2023 at 10:40
Download
S220718-R290823_IOS-Z80-MBC2.zip
The sketch for the IOS (with the needed libraries). Unzip into a folder and open the .ino file (with Arduino IDE). IOS must be uploaded into the Atmega32A flash. Adds support for Fuzix OS and the SPP Adapter board (more info in the changelog inside the .ino file).
Zip Archive -
43.75 kB -
09/24/2023 at 11:59
Download
S220718-R290823_IOS-Z80-MBC2.ino.with_bootloader_atmega32_16000000L.hex
The sketch for the IOS in executable format (.HEX) with the bootloader. This executable file is intended for use with a programmer as the Atmel Ice or AVRISPmkII or others (Fuse bits: High Byte 0xD6, Low Byte 0xAF, Lock Byte 0xCF)
x-hex -
59.90 kB -
09/24/2023 at 12:04
Download
SPP Adapter board - A240721-R270921.zip
All the documentation needed to build the SSP (Standard Parallel Port) Adapter board (A240721-R270921) including schematic, PCB assembling guide, Gerber files for PCB production. PCB is 55mm x 60mm 2-layers.
Zip Archive -
747.10 kB -
09/24/2023 at 15:10
Download
STARTREKV2.BAS
The famous game Super Startrek kindly debugged by a RetroBrew Computer Forum user. Play with Caps-Lock activated! Now the animation works...
bas -
20.18 kB -
08/07/2018 at 16:32
Download
TREKINST.BAS
Instructions for STARTREKV2.BAS
bas -
6.80 kB -
08/04/2018 at 21:48
Download
Examples with Basic.txt
Some examples showing the new "Virtual I/O Engine" with the stand-alone 8K Basic interpreter.
plain -
4.07 kB -
07/31/2018 at 20:57
Download
S220618_IOS-LITE-Z80-MBC2.ino
The "sketch" for the IOS-LITE. IOS-LITE doesn't support the SD (for full SD support use IOS S220718).
x-arduino -
153.28 kB -
07/25/2018 at 16:13
Download
A040618 Gerber.zip
Z80-MBC2 PCB Gerber files.
x-zip-compressed -
244.39 kB -
07/25/2018 at 16:06
Download
A040618 BOM v2.ods
Z80-MBC2 components list.
spreadsheet -
14.43 kB -
09/09/2018 at 11:06
Download
A040618 PCB Layout Guide.zip
Z80-MBC2 components assembly guide.
x-zip-compressed -
79.01 kB -
07/25/2018 at 16:05
Download
A040618 - SCH.pdf
Z80-MBC2 schematic.
162.71 kB -
07/25/2018 at 16:03
Preview
