Lasers Are Hot
08/16/2018 at 00:12 • 0 commentsMade two mistakes, I used my top plate material while cutting the sides, and also left on the film which burned great in the laser cutter. Lots of residue and didn't want to deal with it.
Recut the sides, and taped the next piece for the top.
Ended up with gloss white acrylic top, instead of the matte white with black core. Ran a black sharpie over the rasters and then wiped the gloss with acetone wipes.
Module Tester Power & Calibration
08/12/2018 at 18:30 • 0 comments![]()
Calibration appeared to work. When the case is complete I will fit the LEDs so they sit flush with the face.
Missing 3.5mm Jacks
08/01/2018 at 18:16 • 0 comments![]()
Top and bottom with ICs.
Jacks, case, and calibration left to do.
Some Resistors
07/30/2018 at 22:20 • 0 comments![]()
Richard Hogben
