Hackaday.io Hackaday.io
Sign up Log in
ESP8266-based RGB module
Practice lesson to learn how to drive custom 4x4 RGB matrix on top of regular LED sunk drivers.
edEd
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
3 followers
  • Description
  • Details
  • Files 6
    • View all
  • Components 13
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
617
0
3
2
Team (1)
  • edEd
Join this project's team
  • Assembly pictures
hardware
ongoing project
ESP8266 DM631 rgb led
This project was created on 08/02/2018 and last updated 8 years ago.
Description
Created this little board to learn how to drive RGB 3528 LED's with regular LED driver. Used DM631 drivers with 12bit PWM per channel.
Files
ESP_Lights_Case.skp
Trimble SketchUp 3D Case model with sheet-ready export.
SSEYO Koan Play File - 2.04 MB - 08/09/2018 at 08:44
Download
ESP_Lights_Case.dxf
Main case components for laser cutting.
AutoCAD DXF - 1.17 MB - 08/09/2018 at 08:44
Download
ESP_Lights_Case_reflector.dxf
Reflector piece for Laser cutting.
AutoCAD DXF - 113.53 kB - 08/09/2018 at 08:44
Download
ESP_Lights_smd.dch
DipTrace PCB layout.
dch - 195.01 kB - 08/02/2018 at 13:08
Download
ESP_Lights_smd.dip
DipTrace Schematic.
dip - 244.10 kB - 08/02/2018 at 13:07
Download
View all 6 files
Components
  • 1 × ESP8266 ESP-12E Module Main WiFi / Controller
  • 4 × SMD 0805 10k resistor Support for WiFi module
  • 2 × SMD 6.0x6.0mm Button Reset and UART uploading control for WiFi module
  • 16 × SMD 3528 RGB LED's (KT-SMD3528-RGB)
  • 1 × PLS-4 Connector for UART
View all 13 components
Project Logs
Collapse
  • Case for RGB beauty
    Ed • 08/09/2018 at 08:34 • 0 comments
    Finished enclosure for this module from 3mm acrylic sheet. Looks very nice as for me )
View project log
Log In/Sign up to comment
Sign up with Github
OR
Rimu is a modular electronic product designed to solve various problems through a series of interchangeable modules. We have recently launch
Project Owner Contributor
Rimu: Modular Control, Igniting Creativity
dengtecDengtec
A tileable module with 128 addressable LEDs. Has 120Hz frame refresh and measures 101.59mm x 50.79mm x 13.60mm.
16x8 SPI LED Matrix
pieslordepieslorde
Vivitek beamer lamp rebuild
DIY LED Beamer lamp with Peltier cooling
wishmasterWishmaster
Self-made simple infrared detection module
yanyan
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP8266-based RGB module", please tell us the reason.
Send message
Remove Member
