1Attach the bolts
We will start with the hardest step: attaching the bolts. For this step you will need a second PCB or another kind of template to hold the bolts for you. Insert all the bolts into the holes:
Then cover it with your actual PCB, making sure the front is downwards. Secure it with rubber bands, and fill the holes with solder paste:
Then take your soldering iron, and melt the paste in every hole, stirring to make sure it all melts and catches the bolt properly:
Finally remove the rubber bands and template and wash the excess flux and paste with acetone:
2Bend and solder the barrette
Next bend the the barrette's ends so that they are inline with the middle, and tin them, then solder it in place.
3Solder all remaining components
4Attach the battery
You can use either a battery holder, like I did in this case, or just a bag-like LiPo battery, depending on what you have available. In either case, attach it to the PCB with two-sided tape and solder the wires.
5Attach the Circuit Playground Express
Carefully insert the CPX onto the bolts. Make sure to move all sides at the same time, because otherwise it can get stuck — the fit is rather tight:
Then secure it in place with nuts:
