Uses a fish air pump with a Tee to feed the iron, which is air sealed with High Temp Silicone gasket maker. The nozzle is made from 3mm brass tubing and a 4-40 washer. It simply replaces the stock iron tip!. You can swap back in your regular tip for regular work!.
Pics uploaded
