Several issues have been pointed out that would not be fixed by replacing the wobbly worm gears. Each issue could be addressed individually, but this would be time-consuming.
Therefore I've decided to reduce the scope of my efforts. I plan to continue testing the Pi and DC motors, but to use a conventional, cartesian robot that will be similar (or identical?) to existing open-source designs. This will reduce complexity and make debugging much simpler.
Since I'm rebuilding the robot anyway, I might as well invest in higher-accuracy sensors. Perhaps I'll get some optical encoders. Alternatively, I might make an attempt at using computer vision- others on this website have had success with this approach. I would have to purchase and calibrate a camera of sufficient resolution, but OpenCV definitely has the capability to do this sort of thing (at least to moderate accuracy).
I'll probably post something to this website when (if) I get another robot built and working. But it will probably be a few months (or even a few years).
Daniel James Evans
