How to create your own custom boot image
08/31/2018 at 17:43 • 0 commentsI wrote a tutorial on my Github wiki, on how to create your own custom image for the Blueberry PI.
Since the Allwinner V3s only has 64Mb of RAM, it is a very smart decision to customize your image to fit your needs.
You only need a running Ubuntu / Debian (or other distros) on your PC.
However some knowledge about the Linux terminal is required.
Successfully tested the parallel RGB Interface
08/25/2018 at 16:58 • 1 comment![]()
Since the V3s has a parallel RGB interface, it can directly drive LCD's like the AT050TN33 (480x270) or other even bigger LCD's like the HW800480F-3E-0B-10 (800x480). The Blueberry PI is compatible with every 40 pin RGB LCD.
Since many people were really interested in buying a Blueberry PI, I fixed some minor issues on the current PCB and ordered new PCB's. I will start selling the Blueberry PI on Tindie in the near future.
Marcel Thürmer
