How much does this cost?
08/11/2018 at 21:37 • 0 commentsNot including the 3D parts, we calculate this at ~$85 per sipper. This can be $30 cheaper if you don't need the battery, or just use a cheaper battery. The $30 battery we chose was probably a bit overkill (6600mAh) but we had a bunch around the lab so we used them. We're also thinking ahead to putting WIFI on this device for data transfer and that will require more battery power. BOM in the files area as well.
Sipper video!
08/11/2018 at 20:39 • 0 comments -
Sipper valves
08/11/2018 at 19:53 • 0 commentsWe designed this device using disposable valves from a system called Hydropac. These valves are perfect for this application, they are small, they don't leak, and they are made for mice. Unfortunately they have to be bought in fairly large quantities (~3000). Check to see if your animal facility already uses them and can give you a few, or just buy yourself a lifetime supply (we did!).
We have also experimented with some other valves that can be bought in smaller quantities. These are sold for farming or pet applications. We tried out plastic valves like this:
https://www.amazon.com/Chicken-Poultry-Nipple-Drinker-Feeder/dp/B01N1QQP07
They are super cheap (~25 cents each) but they don't seem ideal in this application. Perhaps someone can adapt the design but in our hands the sipping area seems too large such that the mice can get liquid without being detected by the device.
We also looked at some metal ones, but I wouldn't recommend them as they were too hard to get liquid out of, I think they are designed with larger animals in mind).
https://www.amazon.com/Livestocktool-Drinkers-Automatic-Waterers-Equipment/dp/B07D1218V6
Hello sip world!
08/11/2018 at 19:42 • 0 commentsAugust, 2018: We have updated the sipper device to a new version and put the design files and code online. Please give feedback below!
