isolated RS422/RS485 shield for professional use
Arduino_RS485 Shield schematic V01-01-00.pdfAdobe Portable Document Format - 210.13 kB - 08/14/2018 at 08:58 |
Datasheet RS485 shield Rev A.pdfDatasheet including Jumper and DIP switch settingsAdobe Portable Document Format - 1.86 MB - 08/14/2018 at 08:56 |
New blog on arduino.cc how to read out an electricity meter via RS485 and Arduino
A new tutorial is available at Arduino.cc and Instructables.com. How to use industrial encoders with RS422 output with Arduino and our Arduino RS422 shield:
https://www.instructables.com/id/How-to-Use-Industrial-Encoders-With-Arduino/
New documentation how to mount this shield into a din rail enclosure:
its possible to stack up to 3 RS485 shields to an Arduino (or compatible) board. You can connect the Arduino to 3 independet RS485 busses in this case
Test run of a RS485 connection of a Raspberry Pi (left position), Arduino 101 and Arduino UNO (right).... This setting can be extended to up to 255 devices and a distance over 1km
assembled RS422/RS485 shields for Arduino - fresh from the factory - waiting for new owners
https://www.hwhardsoft.de/english/projects/rs485-arduino/
Instructable "How to use MODBUS with Arduino" finished
