Read out an electricity meter via RS485
11/13/2020 at 06:30 • 0 commentsNew blog on arduino.cc how to read out an electricity meter via RS485 and Arduino
Tutorial How to Use Industrial Encoders With Arduino
02/06/2020 at 16:27 • 0 commentsA new tutorial is available at Arduino.cc and Instructables.com. How to use industrial encoders with RS422 output with Arduino and our Arduino RS422 shield:
https://www.instructables.com/id/How-to-Use-Industrial-Encoders-With-Arduino/
How to connect to NMEA-0183
01/30/2019 at 09:54 • 0 comments -
Din rail mount
10/29/2018 at 06:49 • 0 commentsNew documentation how to mount this shield into a din rail enclosure:
Instructable: Up to 3 RS485 Busses on One Arduino
09/07/2018 at 08:13 • 0 comments -
2 RS485 Shields on one Arduino Board
09/06/2018 at 06:34 • 0 commentsits possible to stack up to 3 RS485 shields to an Arduino (or compatible) board. You can connect the Arduino to 3 independet RS485 busses in this case
RS485 test connection
08/28/2018 at 08:17 • 0 commentsTest run of a RS485 connection of a Raspberry Pi (left position), Arduino 101 and Arduino UNO (right).... This setting can be extended to up to 255 devices and a distance over 1km
our shield on Arduino.CC
08/26/2018 at 07:25 • 0 comments -
assembled RS422/RS485 shields are available
08/21/2018 at 11:54 • 0 commentsassembled RS422/RS485 shields for Arduino - fresh from the factory - waiting for new owners
https://www.hwhardsoft.de/english/projects/rs485-arduino/
Instructable "How to use MODBUS with Arduino"
08/19/2018 at 09:27 • 0 commentsInstructable "How to use MODBUS with Arduino" finished
