this version has 16x16 working quickly on ili9341. 32x32 mode is about to be uploaded. current 16x16 drivers are only completed enough to allow for 16x16. when 32x32 mode is ready 16x16 will be re uploaded with latest drivers. 64x64 sub sampling should be working by end of week. it already works for st77xx displays, the ili9341 has 4 times as many pixels and also requires different display drivers. the above download link should work out of box for ili9341, and amd8833 sensor
