• To be continued
    andriy.malyshenko07/08/2020 at 20:42 0 comments
    Want to advertize evolution of this design in new project of mine Onion Omega Hi-Fi Dock. In this new run i want to connect proper I2S DAC to Onion. PCM5102 seems to be perfect candidate. See you there:)
  • Some reflections
    andriy.malyshenko09/20/2018 at 07:27 0 comments
    After being used for several month, here are some reflections
    1) For some audiotracks audio getting distorted after some playback time (sounds like vynil sound), after i press stop and play again - it gets better. I guess that's an indication that some issue with pulseaudio is there. I would like to upgrade pulse from version 6 to 9, but for now i have kernel panic with latest and not able to solve it yet.
    2) I have a feeling that wifi is not the best option. I would like to replace it with ethernet, but for now don't have time to assemble ethernet connector.
    3) I will try to assemble orange-pi version of the same, eventually i want to have hi quality DAC attached to it, instead of sound card, and i failed to make it work with Omega. Seems that omega is quite troublesome in terms of sw, i really wish to keep it for it's low power consumption and low hw (and therefore no hw underutilization), but i don't have time and competence to solve those issues with sw.
    4) Sometimes i see that connection to pulse from my laptop is lost, and pulse restart helps. I guess i should be fixed by running it via ethernet.
  • Jukebox configuration
    andriy.malyshenko08/22/2018 at 20:18 0 comments
    I created Mopidy docker image to utilize network audio server with my audio collection
    Docker is hosted on OrangePi Zero mini computer. I will not cover docker configuration since it is not part of the project.
    Sources can be found here
    To install this as a service create file /etc/systemd/system/mopidy-docker.service with following content (please change settings where necessary)
    [Unit]
    Description=dockerized mopidy
    Requires=docker.service
    After=docker.service
    [Service]
    ExecStartPre=-/usr/bin/docker rm -f mopidy-instance
    ExecStartPre=-/usr/bin/docker pull andreymalyshenko/mopidy:armhf
    ExecStart=/usr/bin/docker run  --name mopidy-instance -p 6680:6680 -p 8011:8011 -v /data2/muzlo:/media:ro -v /var/lib/mopidy:/var/lib/mopidy -e PULSE_SERVER=192.168.1.80  andreymalyshenko/mopidy:armhf
    ExecStartPost=/bin/sh -c 'while ! docker ps | grep mopidy-instance ; do sleep 0.2; done'
    ExecStop=/usr/bin/docker rm -f mopidy-instance
    TimeoutSec=0
    RemainAfterExit=no
    Restart=always
    [Install]
    WantedBy=multi-user.target
    then execute
    sudo systemctl daemon-reload
    sudo systemctl start mopidy-docker.service
    if you see it is running OK and available at http://host:6680 enable service startup
  • Onion Omega configuration
    andriy.malyshenko08/22/2018 at 20:06 0 comments
    After I start it up and followed initial configuration (manual) I did following steps
    0) Assign fixed ip on my router
    1) Added pub key to /etc/dropbear/authorized_keys - so i can ssh to it without password, saves a lot of time
    2) Install pulseaudio version 6 (warn: version 9 gives me kernel panic), please check your sources list to be sure
    opkg update
    opkg install bluez-libs bluez-utils pulseaudio-daemon pulseaudio-tools alsa-lib alsa-utils
    3) change pulseaudio start script at /etc/init.d/pulseaudio
    procd_set_param command $PROG --system --disallow-exit --no-cpu-limit --realtime
    #procd_set_param command $PROG --system --disallow-exit --no-cpu-limit -v --log-target=file:/tmp/pulse.log
    first line - realtime flag solved some sound distortion issues for me
    second line is for debug, you can trace issues in the log file
    4) change pulse config at /etc/pulse/system.pa
    add these lines
    ### PulseAudio available over the network
    load-module module-native-protocol-tcp auth-ip-acl=127.0.0.1;192.168.1.0/16 auth-anonymous=1
    i had no issues with sound drivers, sounf card just started to work out of the box so to speak
    End result:
    pactl list sinks short
    1	alsa_output.default	module-alsa-sink.c	s16le 2ch 44100Hz	SUSPENDED
     5) At this point it is possible to test network audio from laptop within same network
    copy system config from /etc/pulse/default.pa to  ~/.config/pulse/default.pa
    Add these line
    load-module module-tunnel-sink-new server=192.168.1.80 sink_name=onion
    After pulse restart i can select network card in my audio settings and test that audio works fine
    6) Add following script at  /sbin/pa-monitor
    #!/bin/ash
    GPIO=19
    function main {
    	while (true); do
    		state=$(pactl list sources short | awk '{print $7}')
    		if [ $state = "SUSPENDED" ]; then
    			off;
    		else
    			on;
    		fi
    		sleep 1
    	done
    function init {
    	gpioctl dirout $GPIO
    function on {
    	echo "ON"
    	gpioctl dirout-high $GPIO > /dev/null
    function off {
    	echo "OFF"
    	gpioctl dirout-low $GPIO > /dev/null
    main
    Add startup script at /etc/rc.local
    /sbin/pa-monitor > /dev/null &
    enable  /etc/rc.local
    chmod a+x /etc/rc.local
    After that relay should automatically swith on amp as soon as audio start playing, when audio switched off after ~15 seconds relay shuts off.
  • Onion Omega hardware
    andriy.malyshenko08/22/2018 at 19:26 0 comments
    I used two storey perfboard to assemble together following components
    1) Onion Omega node
    2) micro usb power connector
    3) 5v to 3.3v linear power convertor to power onion node
    4) Conexant usb sound card (just what i had laying around). Originally i was planning to use I2S DAC but i found issues firing it up with onion node and downgraded to this simple usb card. One day i might fix it up and get back to DAc that i have prepared for that
    5) Small schematic to power relay switch
    This sandwich assembled on the back panel of my amp, which is hidden inside my couch and have no direct access. Relay module controlled by Omega replaces power switch inside my amp. This allows me to have it off when i don't need it and save some considerable amount of electricity.
    Relay module is taken from pretty standart arduino relay module. I changed schematics with the one proven to work more reliable from 3.3v level line.
    Whole Omega sandwich eats around 300mA of usb power.
