Matrix_Program_Final.zip
The final (working) code files that make the magic happen
Zip Archive -
7.05 kB -
02/24/2019 at 17:49
Download
MatrixArrayGenerator.java
just draw the images and this will handle the tedious parts.
Java Source File -
9.18 kB -
10/15/2018 at 21:55
Download
small pulley.stl
STL file for small pulley gear which attaches to motor
Standard Tesselated Geometry -
452.76 kB -
09/30/2018 at 17:34
Download
primary gear.stl
larger gear with space for 1/4" ball bearing inserts, designed to use a 5/16 bolt as a drive.
2.74 MB -
09/30/2018 at 17:34
Download
bottom load bearing.stl
spacer for end of drive to reduce friction from bolt on the primary gear, has space for 1/4" ball bearings.
95.10 kB -
09/30/2018 at 17:34
Download
top mount.stl
mount for platform to hold display matrix, designed to take 1/4" ball bearings.
258.99 kB -
09/30/2018 at 17:33
Download
