Design Parameters in Construction of Serpentine
A project log for SERPENTINE
Hand Gesture Recognition using Self-Powered Stretchable Squeezable Force Sensor based on Triboelectric Nanogenerators Principle
fereshtehfereshteh • 10/22/2018 at 03:45•0 Comments
Silicone rubber is chosen as the main substrate because of following reasons. Changing the proportions of silicone elastomer and PDMS which is mentioned in fabrication process allows different elasticity for the sensor.
Copper and Silver coated Nylon are chosen as electrodes for following reasons:
