Atari Punk Console on a square 1-inch PCB
Before finalizing the PCB I wanted to test the circuit on breadboard and so I did. Instead of variable resistors I used LDR in the breadboard circuit.
For designing a square inch PCB, I was considering the two PCB designing softwares: Eagle and KiCAD. I chose KiCAD because it is free, also my goal was to learn KiCAD, not just to design a PCB. Initially all my components were THT, but had to replace the 555 timer ICs to the surface mounted ones eventually because of small PCB size.
I used a 2 pin connector for power and two 3 pin connectors for potentiometers, so we can connect other sensors, such as LDR, in place of the variable resistors.
Noticed the two holes above the buzzer? Those are to mount the PCB on something easily (for example, a toy)
On KiCAD, it is so easy to manage the layers and view. KiCAD even has a 3D viewer which Eagle does not have.
A PCB this small and this simple can be easily manually routed, however when we get to much bigger and much more complicated PCBs, autorouting is the best and the safest option. BUT KiCAD does not have any stand-alone autorouter, however we can use several external auto-routers to route any PCB. I used FreeRouting available at FreeRouting.org. Here are the steps involved.
1) Download the FreeRouting jar file
2) Generate and read netlist
3) Export Specctra DSN file in Pcbnew
4) Open the DSN file in FreeRouting
5) Autoroute!
6) Import the saved autorouted specctra session file in Pcbnew
...and you are done. Easy.
