D-duino(Arduino&NodeMCU&ESP8266&0.96OLED)
As you know 2015 is a ESP8266 year. We developed this D-duino(Display duino) for everyone. It is a platform for beginners to learn IOT.
This is a low cost Arduino-compatible ESP8266 development board. It intergrated a 0.96OLED. You can use Arduino IDE to programme it. Also you can use LUA to programme it(NodeMCU).You can use this module make a wifi scanner. Or a weather station. Or any information from internet you want to show.
What makes it special?
All ESP8266 pins broken out.
12 digital pins write/read/interrupt/pwm/I2C/one-wire supported(except D0)
1 analog input
Integrated 0.96″ OLED
Micro USB connection
Compatible with Arduino
Compatible with NodeMCU(Lua for ESP8266)
Code example has already been put on github.
https://github.com/lspoplove/D-duino
SarinaLesch wrote 07/10/2020 at 06:01 point
From my point of view, there is not a better platform other than the D-duino that can teach others a lot of significant stuff about the IoT in the easiest way. Mostly students like to read bestessay.com reviews so as to complete their work on time. It is the best platform devised for beginners and seekers.
