See it in action
Startup
When you plug in the emonica, the pressure sensor will be calibrated to the environment. So, don't blow into the emonica, when you start up.
Slider calibration
Since there are no reference points for the slider, the slider must be moved right and left once. A little animation shows the whole thing. After this, the emonika is ready for use.
Button assignment & menu structure
Here you see an image of the buttons. Each button can be assign to a special function (see menu structure).
Menu structure
When you start the emonica you are on the main screen, where you can see the current preset, current note and the blow in/out level of the pressure sensor.
If you press all six buttons for more than three seconds, you get into the setting mode.
At the first , you can select the preset. There are eight presets, but the maxium number is changeable in the source code. Use Buttons 4 and 5 for selecting the current preset.
If you now use the buttons 1 and 2 you can navigate through the parameters for the selected preset.
Parameter description
Pressure threshold
- With the pressure parameter, you determine from which pressure the emonica should react. If you are over this value, the emonica sends out a MIDI-Note and if set, a CC-Value.
Maximum pressure
- This value sets the upper range for the blow in/out level.
CC Midi-Channel for blow
- This value defines the Midi-Channel for the controller change.
CC Midi Controller for blow
- This value defines the Midi-Contoller number for the CC event. E.g. you want to change the cut off filter on a synth dynamically or the expression.
CC MIDI minimum value for blow
- If you exceed the threshold, this value will be sent as the smallest Midi-Value.
CC MIDI maximum value for blow
- This is the MIDI-Value, which will be send when you reached the maximum pressure value.All values between will be mapped between the pressure threshold and the maximum pressure.
Note MIDI-Channel
- This value sets the MIDI-Channel where the note will be send, when you hitting the thresold.
Low/(Root) Note
- Here you can select the first note on the emonica (on the left). E.g. select the "A3" for the first note.
Highest Note
- On the highest note you can select the last note on the right side of the emonica. All notes between will be calculated, depending of the scale you use. (See parameter: Tone scale)
Tone scale
- This is the most important settings and requires a little music theory.
Here is a short example. Let's say you have a piece of music that is played in A minor.
As a root note you can then choose an A3 and as the highest note the A4.
If you now set "minor" on the Tone Scale, the emonica will calculate all appropriate tones for the minor scale. This has the advantage that the notes that are not normally played in a minor harmony are suppressed.
It becomes even easier if you use the pentatonic tone scales.
Of course, you can also adjust the whole scale to chromatic, then you'll have all 12 tones of the scale available, but that requires a lot of practice. :-)
Dynamic Expression
- With the dynamic expression parameter you can select if you want to have a dynamic or static value for the expression (volume). When you select dynamic expression, the value depends of the pressure when you blow in/out.
Dynamic expression minium value
- If you're using the dynamic expression, you have to define the lowest value of the expression when the blow-threshold is exeeded.
Dynamic expression maximum value
- This value defines the maximum expression (volume) value, which will be send, when you reached the maximum pressure value.
All values beween will be mapped between the pressure thresold and the maximum pressure.
Static Expression
- If you disable dynamic expression, a fixed value will be send which can be defined here.
Button assignment
Select Button Type
- For each button a function can be defined.
At the moment there are four different possibilities. :
Transpose
Slide
Send CC-message
Send MIDI-Note
The Button-assignments will be repeated for all six buttons.
Button Type - Transpose
- If the button is assigned as a transpose-button, you can select the value on which the note will be transposed.
E.g. if you want so transpose the note up an ocatve you can select the value 12 (half notes) or if you want to change it an octave lower, select -12.
Button Type - Pitch Bend
Pitch Bend To
- When you assign the button to slide, you can select to which semitone the to should be slide. You can use this, to emulate a whammy bar. Also negative values are possible.
Pitch Bend speed
- Defines the speed, when the maximum (pitch to) should be reached.
Button Type - Send CC
CC Midi-Channel
CC Midi-Controller
- This value defines the Midi-Controllernumber.
CC Minimum Value (or release value)
Here you define, which value will be send, when you release the button.
CC Maximum Value (or press value)
- Here you define, which value will be send, when you press the button.
Button type - Send Midi Note
Send Midi Note - Note
- Define the note which will be send on button press.
Midi Note Channel
- Defines the MIDI-channel where the note will be send.
Midi Note Expression (Volume)
- Defines the expression value when the note will be send.
Finally I would like to apologize for my bad english :-)
