1Solder LEDs
Solder LEDs together:
- Anode red to Cathode green
- Cathode red to Anode green
2Solder resistors
Solder a 10KΩ 1W resistor to each LED solder joint.
3Solder power cord
Solder the other side of each resistor to one of the wires of the power cord.
4Safety
Inspect contraption that non of the solder joints touch each other. Insulate all solder joints appropriately with electrical tape or heat shrink.
5More safety
Put LEDs and resistors on a non-flameable non-conductive surface.
6Plug in
Do NOT hold the resistors or LEDs in your hands and then plug the power plug into an outlet. Enjoy LEDs blinking. If you have a new phone with high speed video recording, I really would like to see a slow motion video to actually see the LEDs blinking.
