Hopefully this is a full speed USB hub, so it can be used to chain PCM2906 sound cards without degrading performance. If not, well, it'll still work for slower things.
Board sent off to OSHPark september 1st, all components are in hand. Here we go.
Gotta have more USB ports
FE1.1S-inch.schfirst testsch - 388.29 kB - 09/02/2018 at 06:42 |
FE1.1S-inch.brdfirst testbrd - 73.33 kB - 09/02/2018 at 06:42 |
It works! Nothing much to the design but some capacitor filtering and a specific resistor value. It takes 5 volts and shows up as a High-speed USB device:
usb 1-3.2.4: new high-speed USB device number 47 using xhci_hcd
usb 1-3.2.4: New USB device found, idVendor=1a40, idProduct=0101
usb 1-3.2.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-3.2.4: Product: USB 2.0 Hub
hub 1-3.2.4:1.0: USB hub found
hub 1-3.2.4:1.0: 4 ports detected
So thats cool. I cheaped out on the decoupling capacitors for the crystal, as other designs I'd seen didn't have them. It worked without them, and they're trivial to add. I could shrink this further by getting more aggressive with the pad layout, using one of those 2.5 x 2mm crystals, and 0603 passives.
Awesome! This kind of project is why I love the square-inch contest. Simple. well-executed, and done. Open for anyone to copy.
Thanks!
Where did you source the FE1.1S from? I'm, finding it difficult to find in the US.
