To learn basic of autonomous system, I thought an idea of making rover avoid the obstacles. To achieve this I used OpenCV module for image processing. The camera on Rover gives H264 frame to android app, after that on android side frame is decoded to MAT object of OpenCV then that MAT object is used in OpenCV algorithm to detect the object and to know its position and radius. Now this x, y position of detected object is compared with current camera frame. Depending on its position in the frame, command of row and throttle is given to PlutoX rover. Drona Aviation will soon release the API on android platform to access the on board camera frame so that tinkerers can use it in image processing on PlutoX platform.
To open drone experimentation to the world, Drona Aviation is crowdfunding for PlutoX on Indiegogo. Support them and help them bring it to life: https://igg.me/at/flyplutox/tinkerers
vedanshi.shah
Nathaniel Wong
G.Vignesh
hanno
Hi Chris, I am working on to release api to access the camera. Please send me your contact details on vedanshi.shah@dronaaviation.com so that I can revert back to you when the apis are ready.
