Open SLM
Building an SLM 3d printer
With Multi Material
Public Chat
Building a SLM 3d printer. Selective laser melting is an additive manufacturing technique designed to use a high power laser to melt and fuse powders. Using granite plates to build the body.
The design requirements are as follows:
NEEDS:
Temperature controlled build chamber.
Powder Extruder with the laser to allow for simple multi material.
Narrowing in on the design.
Current SLM is mostly locked in on one material with very high cost to aquire and operate. Using Granite plates our machine will be low cost, precise and have very good vibration dampening.
V1
Fill a slot with a powder extrusion head and deposit layer by layer. Linear servos, magnetic encoder, and air bearings will allow for precise fast movement.
V2
Multi Material solution: Will use a glut of powder at the tip to approximate a circle of the powder bed design. This allows the powder extrusion system to not be a limiting factor unlike an FDM machine. The main challenge right now is to find a balance of low enough pressure to avoid ignition of metal powders and enough air to pull the extra powder away from the head.
  • Potential Extruders
    Patrick Ryan10/08/2020 at 02:15 0 comments
    Using the partial vacuum in the chamber and atmospheric there is plenty of pressure differential to spray powder, Looking into piezo electric valve similar to inkjet printers (difficult to manufacture) for high precision a magnetic valve for thicker lines.
  • Flat Linear motors are hard
    Patrick Ryan10/08/2020 at 02:03 0 comments
     Going to a cylindrical linear motor design for better strength and ease of manufacture.
  • Square Chambers...
    Patrick Ryan03/13/2020 at 03:03 0 comments
    Could not find a methodology to manufacture the previous design.
  • Paradigm Shift
    Patrick Ryan01/11/2020 at 16:44 0 comments
    Changing the linear system to air bearings, linear drives and magnetic encoders. This will allow for research into better solar cells, energy storage, and processors.
View all 4 project logs
zubiriarkaitz35 wrote 11/27/2022 at 20:23 point
ITS ALIVE?
Patrick Ryan wrote 01/02/2023 at 00:22 point
It was in storage for a while now back out and going to be moving forward.
