This was a freelance job offered to me, unfortunately, I can't share the finished code.
This project was supposed to be a test of concept if automating the sensors in a hydroponics farm will work while still maintaining the accuracy of the readings over-time.
The data gathered was also published to the a cloud server for viewing even if the farm was located at a remote area.
Cedric
Pattern Agents
Horacio Bouzas
Florian Ellsäßer
Hello, I was looking to build the same thing, can you please share your code?
