Hydroponics Sensor
ESP32 based Hydroponics Sensor (Water Flow, Water PPM, Water pH, Water Temperature).
Public Chat
WeMos LOLIN 32 board hooked up to:
DS18b20 Water Temperature Sensor,
Gravity Analog pH Sensor (https://www.dfrobot.com/product-1110.html)
Gravity Analog EC Meter (https://www.dfrobot.com/product-1123.html)
Water Flow Sensor
I used a modified EC probe based from the Three Dollar EC - PPM Meter by Michael (https://hackaday.io/project/7008-fly-wars-a-hackers-solution-to-world-hunger/log/24646-three-dollar-ec-ppm-meter-arduino)
This was a freelance job offered to me, unfortunately, I can't share the finished code.
This project was supposed to be a test of concept if automating the sensors in a hydroponics farm will work while still maintaining the accuracy of the readings over-time.
The data gathered was also published to the a cloud server for viewing even if the farm was located at a remote area.
  • 1
    Some notes
    The ESP-32 board pins operate in 3.3v levels while the Gravity pH and EC sensors operate in 5V. I inserted a simple voltage divider to shift 5v to 3.3v levels on the signal pins.
View all instructions
mihaibogdan.georgescu wrote 04/29/2019 at 10:16 point
Hello, I was looking to build the same thing, can you please share your code?
