Hackaday.io Hackaday.io
Sign up Log in
HoPZBox
The ultimate stompbox. It is not just a stompbox, it is a metronome, a drum machine and more.
laszlo-szelLaszlo Szel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.5k views
0 comments
1 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 6
    • View all
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 0
  • The 2018 Hackaday Prize
View Gallery
1.5k
0
1
2
Team (1)
  • laszlo-szelLaszlo Szel
Join this project's team
  • HoPZBox
ongoing project
2018hackadayprize ESP8266 NodeMCU
This project is submitted for
  • Musical Instrument Challenge
This project was created on 09/05/2018 and last updated 8 years ago.
Description
I am working on a digital age version of the classical folk percussion instrument, the stompbox. This stompbox is not just useful on stage, but it can be a metronome, or a drum machine, with tap-tempo function. It will have a web server inside to get additional user interface and functions from your mobile phone too.
Files
hopzbox.fzz
New schematic with OLED module
fzz - 172.23 kB - 10/30/2018 at 19:56
Download
Components
  • 1 × 3pin Voice Sound Detection Sensor Module
  • 1 × nodemcu
  • 1 × Sparkfun WAV Trigger WIG-13660 module
  • 2 × 16-Channel Analog/Digital Multiplexer/Demultiplexer CD74HC4067
  • 1 × KY-040 rotary encoder and push button
View all 6 components
Project Logs
Collapse
  • OLED module instead of the 8x8 LED matrix
    Laszlo Szel • 10/30/2018 at 20:01 • 0 comments
    I started to use an OLED module instead of the 8x8 matrix. It looks much better :) , and because of the I2C  I need less resource and less I/O pin.
  • Wav Trigger board first test
    Laszlo Szel • 10/07/2018 at 09:23 • 0 comments
    The wav trigger board was arrived
    The wav-triggeer board was arrived, so here is the first soundcheck :)
  • Additional multiplexer/demultiplexer
    Laszlo Szel • 09/27/2018 at 12:00 • 0 comments
    First schematics was redesigned, and added another multiplexer/demultiplexer because of the lac of the enough I/O pins.
  • First hardware test
    Laszlo Szel • 09/25/2018 at 11:32 • 0 comments
  • First test code
    Laszlo Szel • 09/25/2018 at 11:17 • 0 comments
    First parts are arrived and started to write the first codes for sound detector ad for the 8x8 matrix.
    https://github.com/lszel/HoPZBox
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
OR
A simple breakout board for the FLIR Lepton LWIR Camera module specifically giving access to the SPI and I2C pins.
Project Owner Contributor
FLIR Lepton Breakout
danielDaniel
Development board for ESP8266 the make up of which can be decided by the community
ESP8266 Development PCB's
michael-otooleMichael O'Toole
Hackaday Prize 2019
A MIDI sequencer
Beat707
frank-bussFrank Buss
A new way of thinking to a IOT thermostat:
FCThermostat: Another overengeneered IOT device
nicolNicolò
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "HoPZBox", please tell us the reason.
Send message
Remove Member
