OLED module instead of the 8x8 LED matrix
10/30/2018 at 20:01 • 0 comments![]()
I started to use an OLED module instead of the 8x8 matrix. It looks much better :) , and because of the I2C I need less resource and less I/O pin.
Wav Trigger board first test
10/07/2018 at 09:23 • 0 comments
The wav trigger board was arrivedThe wav-triggeer board was arrived, so here is the first soundcheck :)
Additional multiplexer/demultiplexer
09/27/2018 at 12:00 • 0 commentsFirst schematics was redesigned, and added another multiplexer/demultiplexer because of the lac of the enough I/O pins.
First hardware test
09/25/2018 at 11:32 • 0 comments -
First test code
09/25/2018 at 11:17 • 0 commentsFirst parts are arrived and started to write the first codes for sound detector ad for the 8x8 matrix.
Laszlo Szel
