Hackaday.io Hackaday.io
Sign up Log in
HoPZBox
The ultimate stompbox. It is not just a stompbox, it is a metronome, a drum machine and more.
laszlo-szelLaszlo Szel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.5k views
0 comments
1 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 6
    • View all
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 0
  • The 2018 Hackaday Prize
View Gallery
1.5k
0
1
2
Team (1)
  • laszlo-szelLaszlo Szel
Join this project's team
  • HoPZBox
ongoing project
2018hackadayprize ESP8266 NodeMCU
This project is submitted for
  • Musical Instrument Challenge
This project was created on 09/05/2018 and last updated 8 years ago.
Description
I am working on a digital age version of the classical folk percussion instrument, the stompbox. This stompbox is not just useful on stage, but it can be a metronome, or a drum machine, with tap-tempo function. It will have a web server inside to get additional user interface and functions from your mobile phone too.
Files
hopzbox.fzz
New schematic with OLED module
fzz - 172.23 kB - 10/30/2018 at 19:56
Download
Components
  • 1 × 3pin Voice Sound Detection Sensor Module
  • 1 × nodemcu
  • 1 × Sparkfun WAV Trigger WIG-13660 module
  • 2 × 16-Channel Analog/Digital Multiplexer/Demultiplexer CD74HC4067
  • 1 × KY-040 rotary encoder and push button
View all 6 components
Project Logs
Collapse
  • OLED module instead of the 8x8 LED matrix
    Laszlo Szel • 10/30/2018 at 20:01 • 0 comments
    I started to use an OLED module instead of the 8x8 matrix. It looks much better :) , and because of the I2C  I need less resource and less I/O pin.
  • Wav Trigger board first test
    Laszlo Szel • 10/07/2018 at 09:23 • 0 comments
    The wav trigger board was arrived
    The wav-triggeer board was arrived, so here is the first soundcheck :)
  • Additional multiplexer/demultiplexer
    Laszlo Szel • 09/27/2018 at 12:00 • 0 comments
    First schematics was redesigned, and added another multiplexer/demultiplexer because of the lac of the enough I/O pins.
  • First hardware test
    Laszlo Szel • 09/25/2018 at 11:32 • 0 comments
  • First test code
    Laszlo Szel • 09/25/2018 at 11:17 • 0 comments
    First parts are arrived and started to write the first codes for sound detector ad for the 8x8 matrix.
    https://github.com/lszel/HoPZBox
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
OR
Hackaday Prize 2019
A MIDI sequencer
Project Owner Contributor
Beat707
frank-bussFrank Buss
A simple breakout board for the FLIR Lepton LWIR Camera module specifically giving access to the SPI and I2C pins.
FLIR Lepton Breakout
danielDaniel
A new way of thinking to a IOT thermostat:
FCThermostat: Another overengeneered IOT device
nicolNicolò
Development board for ESP8266 the make up of which can be decided by the community
ESP8266 Development PCB's
michael-otooleMichael O'Toole
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "HoPZBox", please tell us the reason.
Send message
Remove Member
