One year ago I published an initial version of STM8EF on GitHub. I was then a near total Forth newbie, and I had no idea where the journey would take me. In just one year STM8EF turned into a very lean but rather complete self-contained Tiny Forth with support for some super cheap Chinese boards with a small but active community!
The latest additions are:
- a Build Framework with include file support, that compiles Forth code into a target binary
- a ucSim based µC simulation with a Forth console
- upcoming STM8EF suppory in e4thcom
- the very beginning of a library
- a decomposable core (linking, and core word includes are optional)
Future work will go in this direction:
- better support for applications that require very high code density (e.g. hybrid STC/ ITC)
- a library with basics like hardware drivers, math, etc (maybe in the form of packages)
- more exchange with the Forth community
- Script-Kits (sic) for typical applications (power supply, lab automation, why not thermostats ;-)
One more thing that happened in just one year: I have to be super careful not to forget how it is not to be a Forther - otherwise the whole thing will be of very little use for the average HaD guy. I guess that there is a need for more spin-off projects that are really easy to build, and simple to understand.
Hi Thomas, sorry I've been busy with other stuff for a while.
Is there source for e4thcom anywhere, or am I missing it? I would love to tweak at it.
Hi Elliot, no problem - I noticed that you've been experimenting with extremely low power LED drivers, an interesting topic. I wonder if ultra low power data transmission would work that way (e.g. with Forth on an STM8S003).
I never discussed the source code with the author - e4thcom is based on https://github.com/andrewtholt/minforth. It would be great if you could send him an email :-)
The configuration file for STM8EF is now on the e4thcom download page: https://wiki.forth-ev.de/doku.php/en:projects:e4thcom
My command line parameters are "e4thcom-0.6.1 -t stm8ef -d ttyUSB0"
