Connecting the W1209 is now really easy:
It's no longer necessary to modify the W1209!
It's been a while since the last release, maybe too many interdependent steps for speedy development. Anyway, most is now tested, and ready to use:
- dictionary headers can be selected on a board-by-board basis (issue #32 )
- make BOARD=xxxx forth target uses tools/codeloadTCP.py and uCsim for code generation with #include feature (issue #32 )
- software full-duplex serial interface, e.g. for e4thcom (issue #41 )
- board W1209-FD with full-duplex serial interface (issue #42 )
- key "+" / PC4: RxD
- key "-" / PC5: TxD
- default HAS_ALIAS=1 allows immediate words in RAM while compiling to NVM (issue #43 )
- a Forth library has been added to code repository, and binary release (issue #43 )
Check out the GitHub Releases page (binaries are included).
Thomas
