1Install software for PC application
- Install Python 2.7 including pip package manager
- Use pip to install OpenCV, Numpy, and serial with:
- Clone or download my project from: https://github.com/dwaq/webcam-pulse-detector
pip install opencv-python matplotlib serial
2Install tools for microcontroller
This step will change depending on the microcontroller that you use, but for the Digispark, follow the instructions here: (BTW, the Tomu looks like a modern replacement to the Digispark)
http://digistump.com/wiki/digispark/tutorials/connecting
After installing the board in the Arduino IDE, a warning will be displayed in the Arduino console with the location of the drivers. Move to this directory and install the drivers manually. Use the drivers linked in this forum post if you're using Windows 10.
Copy this code into a new Arduino project and flash it to the Digispark (note that you hit upload and then insert the Digispark into the USB port when prompted):
#include <DigiCDC.h> // onboard LED pin //#define LED 1 // RGB Shield Red LED pin #define LED 0 void setup() { // begin serial SerialUSB.begin(); // set LED as output pinMode(LED, OUTPUT); } void loop() { if (SerialUSB.available()) { // read the pulse (in beats per minute) sent over serial float pulse_BPM = SerialUSB.read(); // convert pulse to beats per second float pulse_BPS = pulse_BPM/60; // calculate the period of one beat float period = 1/pulse_BPS; // calculate floating point value of the time where the light should be on // assuming the systole lasts 3/8 of a pulse period float time_on_f = 0.375 * period; // convert that time on to an int in milliseconds int time_on = time_on_f * 1000; // calculate the remaining floating point time in the period - "the diastole" float time_off_f = period - time_on_f; // convert the time off to an int in milliseconds int time_off = time_off_f * 1000; // set LED high digitalWrite(LED, HIGH); // delay for the on time SerialUSB.delay(time_on); // set LED low digitalWrite(LED, LOW); // delay for the off time SerialUSB.delay(time_off); } // need to call a SerialUSB function at least every 10ms SerialUSB.refresh(); }After the device is programmed, make note of the serial port that shows up for the communications. It's different than the port that was used to program it and the new port will be needed for the next step.
3Start the PC application
Open a terminal at the location of the project from step 1.4. Use the following command to start in serial mode (ensure you change the COM number to the one you found in step 2.
python get_pulse.py --serial COM5The PC application will start your webcam. Aim the square at your forehead and press the "s" key. Your heart rate will be determined and the LED on the microcontroller will start to blink. Congrats, you're done!
Dillon Nichols
