PSEUDOCODE For Synchronia♥Duet Firmware
A project log for Synchronia♥Duet
Synchronia♥Duet, a Musical Instrument built for two!
thomas-r-mahannaThomas R. Mahanna 10/05/2018 at 14:090 Comments
The Following is a pseudocode listing of the Synchronia-Duet Firmware. It can be readily adapted to any compiler.
PSEUDOCODE
'  Synchronia--Duet 0.0.7
' (C)2018 Thomas R. Mahanna
'CONFIGURE HARDWARE I/O (ATMEGA2560 in the Case of the Prototype)
'Configure Communication
Open Serial1 For Binary As #0		'Serial Connection to PC
Open Serial2 For Binary As #1           'MIDI Out / QUNexus In
Open Serial3 For Binary As #2           'UNZTRUMENT I/O
'DIMESION VARIABLES
'Serial Input Variables
Dim SerialInbyte As Byte
Dim SerialFlag As Bit
Dim QuNexusInbyte As Byte
Dim QuNexusFlag As Bit
Dim UntzInbyte As Byte
Dim UntzFlag As Bit
'MIDI Variables
Dim MIDICh as byte
Dim Timbre as Byte
Dim Status As Byte
Dim Data1 As Byte
Dim Data2 As Byte
Dim StrumDelay As Byte
Dim ChordArray(4) as Byte
Dim ScaleArray(5) as Byte
Dim Vel as Byte
Dim Pedal as bit
Dim Notes(5) as Byte
'Main Variables
Dim I As Byte
Dim ChordType As Byte
Dim OldChord As Byte
Dim Root As Byte
Dim OldRoot As Byte
Dim OldChordButton As Byte
Dim OldRootButton As Byte
Dim ButtonHold As Bit
Dim Offset as Byte
Dim Temp as byte
'DEFINE IRQ HANDLERS
On Serial1 PCSerial_isr
On Serial2 Qunexus_isr
On Serial3 Untz_isr
'ENABLE INTERRUPTS
Enable IRQ0
Enable IRQ1
Enable IRQ2
Enable Global Interrupts
'DEFINE / DECLARE SUBROUTINES
Declare Sub Midiout(byval Ch As Byte , Byval Note As Byte , Byval Vel As Byte)
Declare Sub Midipatch(byval Ch As Byte , Byval Patch As Byte)
Declare Sub Mastervolume(byval Vol As Byte)
Declare Sub Allnotesoff
Declare Sub ProcessUntzButton
'MAIN
' Entering Main Loop
For I = 0 To 15   SerialOut #2 , I                      'All Chord Buttons Off   Waitms 1
Next
For I = 76 To 79   SerialOut #2 , I   Waitms 1
Next
For I = 92 To 95  SerialOut #2 , I  Waitms 1
Next
For I = 108 To 111   SerialOut #2 , I                      'All Trellis Root Buttons Off   Waitms 1
Next
Chordtype = 0
SerialOut #2 , 140
OldChordButton = 12
Root = 0
SerialOut #2 , 204
OldRootButton = 76
Offset = 48                             'Octave 4 * 12
Call ProcessUntzButton
MIDICh = 1                              'Set MIDI Output Channel
Timbre = 0                              'GM Piano [0]
Vel = 96                                'Velocity
StrumDelay = 40                         'Spread Between Notes (mS)
Pedal = 1                               'Pedal off
SerialOut #1 , &HB0
SerialOut #1 , &H7B
SerialOut #1 , &H00                      'All Notes Off
SerialOut #1 , 176
SerialOut #1 , 7
SerialOut #1 , 64                        'Set Volume to 96
Call Mastervolume(64)                   'Set Volume to 96
Call Midipatch(midich , Timbre)         'Change MIDI Intrument Timbre
Do   '// PROCESS UNTZTRUMENT   If UntzFlag = 1 Then      Select Case UntzInbyte
      '// Button Release            Case 12               ButtonHold = 0            Case 13               ButtonHold = 0            Case 14               ButtonHold = 0            Case 15               ButtonHold = 0
            Case 16 to 127               If Pedal = 0 then                  Call MIDIOut(MIDICh , ChordArray(1) , 0)                  Call MIDIOut(MIDICh , ChordArray(2) , 0)                  Call MIDIOut(MIDICh , ChordArray(3) , 0)                  Call MIDIOut(MIDICh , ChordArray(4) , 0)               End If
      '// Chord Selection           Case 140               Chordtype = 0            'Major               SerialOut #2 , OldChordButton       'Turn old chordtype button off               SerialOut #2 , UntzInbyte 'Turn new chordtype button on                If UntzInbyte > 127 Then                  OldChordButton = UntzInbyte - 128               Else                  OldChordButton = UntzInbyte               End If               Buttonhold = 1               Call ProcessUntzButton           Case 141               Chordtype = 1            'Minor               SerialOut #2 , OldChordButton       'Turn old chordtype button off               SerialOut #2 , UntzInbyte 'Turn new chordtype button on               If UntzInbyte > 127 Then                  OldChordButton = UntzInbyte - 128               Else                  OldChordButton = UntzInbyte               End If               Buttonhold = 1           Case 142               Chordtype = 2            'Sus4               SerialOut #2 , OldChordButton       'Turn old chordtype button off               SerialOut #2 , UntzInbyte 'Turn new chordtype button on               If UntzInbyte > 127 Then                  OldChordButton = UntzInbyte - 128               Else                  OldChordButton = UntzInbyte               End If               Buttonhold = 1           Case 143               Chordtype = 3            'Dom7               SerialOut #2 , OldChordButton       'Turn old chordtype button off               SerialOut #2 , UntzInbyte 'Turn new chordtype button on               If UntzInbyte > 127 Then                  OldChordButton = UntzInbyte - 128               Else                  OldChordButton = UntzInbyte               End If               Buttonhold = 1
           '// Root Selection           Case 204               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 0                 'Root C               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 205               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 1                 'Root C#               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 206               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 2                 'Root D               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 207               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 3                 'Root D#               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 220               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 4                 'Root E               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 221               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 5                 'Root F               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 222               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 6                 'Root F#               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 223               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 7                 'Root G               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If               'Print "Root  = G"         Case 236               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 8                 'Root G#               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 237               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 9                 'Root A               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 238               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 10                'Root A#               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         Case 239               SerialOut #2 , OldRootButton       'Turn old root button off               SerialOut #2 , UntzInbyte 'Turn new root button on               Root = 11                'Root B               Call ProcessUntzButton               If ButtonHold = 1 Then                  Call MIDIOut(MIDICh , ChordArray(1) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(2) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(3) , Vel)                  waitms StrumDelay                  Call MIDIOut(MIDICh , ChordArray(4) , Vel)                  waitms StrumDelay               End If               If UntzInbyte > 127 Then                  OldRootButton = UntzInbyte - 128               Else                  OldRootButton = UntzInbyte               End If         End Select      UntzFlag = 0  End If
 '// PROCESS QUNEXUS   If QuNexusFlag = 1 Then      If Data2 > 0 then         Select Case Data1         '// Process White Keys            Case 48               Temp = ChordArray(1) - 12            Case 50               Temp = ChordArray(2) - 12            Case 52               Temp = ChordArray(3) - 12            Case 53               Temp = ChordArray(4) - 12
            Case 55               Temp = ChordArray(1)            Case 57               Temp = ChordArray(2)            Case 59               Temp = ChordArray(3)            Case 60               Temp = ChordArray(4)
            Case 62               Temp = ChordArray(1) + 12            Case 64               Temp = ChordArray(2) + 12            Case 65               Temp = ChordArray(3) + 12            Case 67               Temp = ChordArray(4) + 12
            Case 69               Temp = ChordArray(1) + 24            Case 71               Temp = ChordArray(2) + 24            Case 72               Temp = ChordArray(3) + 24
      '// Process Blue Keys            Case 49               Temp = ScaleArray(1)            Case 51               Temp = ScaleArray(2)            Case 54               Temp = ScaleArray(3)            Case 56               Temp = ScaleArray(4)            Case 58               Temp = ScaleArray(5)
            Case 61               Temp = ScaleArray(1) + 12            Case 63               Temp = ScaleArray(2) + 12            Case 66               Temp = ScaleArray(3) + 12            Case 68               Temp = ScaleArray(4) + 12            Case 70               Temp = ScaleArray(5) + 12         End Select
         Call MidiOut(MIDICh , Temp , Vel)
         Else            If Pedal = 0 Then               Select Case Data1               '// Process White Keys                  Case 48                     Temp = ChordArray(1) - 12                  Case 50                     Temp = ChordArray(2) - 12                  Case 52                     Temp = ChordArray(3) - 12                  Case 53                     Temp = ChordArray(4) - 12
                  Case 61                     Temp = ScaleArray(1) + 12                  Case 63                     Temp = ScaleArray(2) + 12                  Case 66                     Temp = ScaleArray(3) + 12                  Case 68                     Temp = ScaleArray(4) + 12                  Case 70                     Temp = ScaleArray(5) + 12               End Select               Call MidiOut(MIDICh , Temp , 0)            End If
      End If      QuNexusFlag = 0   End If
Loop
Sub MIDIOut(Byval Ch As Byte , Byval Note As Byte , Byval Vel As Byte)   Ch = &H8F + Ch   SerialOut #1 , Ch   SerialOut #1 , Note   SerialOut #1 , Vel
End Sub
Sub MIDIPatch(byval Ch As Byte , Byval Patch As Byte)   Ch = &HBF + Ch   SerialOut #1 , Ch   SerialOut #1 , Patch
End Sub
Sub MasterVolume(byval Vol As Byte)   SerialOut #1 , 176   SerialOut #1 , 7   SerialOut #1 , Vol
End Sub
Sub AllNotesOff   SerialOut #1 , &HB0   SerialOut #1 , &H7B   SerialOut #1 , &H00                   'All Notes Off
End Sub
Sub ProcessUntzButton   ChordArray(1) = Root + Offset   ScaleArray(1) = Root + Offset   Select Case ChordType      Case 0                            ' Major         ChordArray(2) = ChordArray(1) + 7         ChordArray(3) = ChordArray(1) + 16         ChordArray(4) = ChordArray(1) + 24
         ScaleArray(2) = ScaleArray(1) + 2         ScaleArray(3) = ScaleArray(1) + 4         ScaleArray(4) = ScaleArray(1) + 7         ScaleArray(5) = ScaleArray(1) + 9      Case 1                            ' Minor         ChordArray(2) = ChordArray(1) + 7         ChordArray(3) = ChordArray(1) + 15         ChordArray(4) = ChordArray(1) + 24
         ScaleArray(2) = ScaleArray(1) + 3         ScaleArray(3) = ScaleArray(1) + 5         ScaleArray(4) = ScaleArray(1) + 7         ScaleArray(5) = ScaleArray(1) + 10      Case 2                            ' Sus4         ChordArray(2) = ChordArray(1) + 7         ChordArray(3) = ChordArray(1) + 17         ChordArray(4) = ChordArray(1) + 24
         ScaleArray(2) = ScaleArray(1) + 2         ScaleArray(3) = ScaleArray(1) + 5         ScaleArray(4) = ScaleArray(1) + 7         ScaleArray(5) = ScaleArray(1) + 9      Case 3                            ' Dom7         ChordArray(2) = ChordArray(1) + 7         ChordArray(3) = ChordArray(1) + 16         ChordArray(4) = ChordArray(1) + 22
         ScaleArray(2) = ScaleArray(1) + 2         ScaleArray(3) = ScaleArray(1) + 4         ScaleArray(4) = ScaleArray(1) + 7         ScaleArray(5) = ScaleArray(1) + 10   End Select
End Sub
PCSerial_isr:   SerialInbyte = Udr   SerialFlag = 1
Return
QuNexus_ISR:   QuNexusInbyte = UDR1   Select Case QuNexusInbyte      Case &H80 to &H9F                 'Note On / Off         Status = QuNexusInbyte         Data1 = &HFF         Data2 = &HFF      Case 0 To 127                     'Data         If Status > 0 Then            If Data1 = &HFF Then               Data1 = QuNexusInbyte            Else               Data2 = QuNexusInbyte               QuNexusFlag = 1            End If         End If   End Select
Return
Untz_isr:   UntzInbyte = Udr2   UntzFlag = 1
Return
Rich text editor
