1Schematic & layout Design
we had taken different type of peripherals in Schematic which we want to use in our board, for design this schematic we had used AutoDesk EAGLE CAD Tool. The design is made taken into consideration of the different requirements of the ICs used in the board.
2PCB Fabrication
After design layout it checked layer by layer in gerbview software and then it is given for the fabrication. After the PCB is received, the components are soldered in the main PCB and are checked for any short connections.
3Testing of Board
working of development board and all peripherals are checked by different codes
