Progress till 25-11-2018
11/26/2018 at 08:38 • 0 commentsThe remote was interfaced to lpc .
Functionality of the remote was verified on the pc.
Progress till 21-11-2018
11/26/2018 at 08:37 • 0 commentsChanged the report format of usb descriptor to keyboard format.
Checked that micro-controller is being detected as hid keyboard interface device.
For different scan-codes of keyboard,functionality is checked in the pc.
Changed the code in remote.c file for appropriate working of remote controlled slide.
-- TO DO --
Interfacing the remote-controller to pc through micro-controller and testing the slide change for appropriate key press.
Progress till 30-10-2018
11/26/2018 at 08:31 • 0 commentsTransmitter,receiver,encoder and decoder were tested.
Connected the push buttons to required data lines of encoder.
Remote controller circuit was designed.
Designed and checked receiver end circuit.
Proper output for pressing of push buttons were tested.
--TO DO--
Making LPC2148 as a hid keyboard device
