The idea is to build a 80cm x 80cm backlit picture frame that's look like a Polaroid print.
The main structure is in wood and milled to
The front is in PMMA
The edges in Acrylic laser cut
- tactile switch
- size 80 cm x 80 cm
- colorful textile power cords
- exchangeable photo print
- wall mount hanger with level
---------------------------------------------------------THE------- RESULT ------------------------------------------------------
![](https://cdn.hackaday.io/images/4640051539345154614.png)
![](https://cdn.hackaday.io/images/1219431539345174640.png)
