In the search for a suitable relay to make the music, I found a DC motor with an off set weight. I thought that I would possibly use a motor, and a relay (built around a solenoid) to make the sounds. I ran tests with the motor running at various speeds using the PWM pins on a SparkFun pro mini. I will soon have an Idea of what the final direction will be.
Boelens, Leland
Paul Stoffregen
agp.cooper
