I got the idea from Chris Holden at http://nerdclub-uk.blogspot.com/2017/01/light-up-lego.html
I still want to turn this into diorama (for example) and put it in a shadowbox, so I can hang it on the wall.
LED lit Lego Lightsaber
Great to hear. What did you do for the base? I still trying to figure out how to display them nicely.
Sorry for the late reply. I only just notices your comment.
I used either a 0.9mm or 1mm carbide drill from ebay, place inside a dremel. I probably used the dremel shaft extension for that one.
For the wiring I used two 0.1mm enameled copper wires, twisted together.
Had someone help me with it a month or two ago and he brought the drill bits and did the drilling while I did the soldering. It turned out pretty nice.
