KickOff Euler Magnification for Audio Looper
09/23/2018 at 20:09 • 0 commentsDuring this kickoff weekend, I started from great work from chairman at github https://github.com/chairmank/eulerian-audio-magnification and check on the theory of it, plus add spectrograms for after and before the magnification.
Add google colab python 2.7 notebook.
Feel free to checkit out!
https://colab.research.google.com/drive/1pXwTn74pyo7VxgWxbv4-r3TsilSSaMrO
next steps will involve set everything up in the rpi, the main part of code published here follows. Laplacian pyramids rock :-)
this the first test results amplifying simple raw wav file with technique described
The main piece of code for that ;-)
window = 1024 step = window / 4 print "whitening spectrum" whitened = sp / np.sqrt(power) whitened = normalize_total_power(whitened, utils.total_power(sp)) print "unwhitening spectrum" unwhitened = whitened * np.sqrt(power) unwhitened = normalize_total_power(unwhitened, utils.total_power(sp)) print "resynthesizing from whitened-unwhitened spectrogram" resynth = resynthesize(unwhitened) wavfile.write("resynth.wav", int(2 * nyq), resynth) print "constructing Laplacian pyramid" pyr = stft_laplacian_pyramid(sp) print "amplifying components of Laplacian pyramid" passband = [0.5, 1.0] fs = 44100 / step gain = 10.0 amplified_pyr = amplify_pyramid(pyr, passband=passband, fs=fs, gain=gain) print "resynthesizing spectrogram from amplified Laplacian pyramid" pyramid_resynth = resynthesize(amplified_pyr.sum(axis=-1)) wavfile.write("resynth_pyramid.wav", int(2 * nyq), pyramid_resynth) (nyq, signal2) = slurp_wav("resynth_pyramid.wav", start=0, end=44100*10) plt.specgram(signal2, cmap='Spectral', Fs=framerate)
