The second last part to print, if everything goes as planned. Looks rather complicated part, but this will ensure a pressure on the upper PCB, which was also kindly provided by JLCPCB to keep it on place and a mount for the 5v fan. Print time @50% infill, with support, 0.2mm layers, 50mm/s : 1h36
