Some words on the buildup.
I lasercuted three sheets of acrylic. Two times in black one in some translucent white. They are held together by distance bolts. My Idea was to screw the LED panels to the middle one and the rest of the electronics to the bottom one... Well, since holes didn't fit, I ended up using hotglue.
For the panels i took some wood, which was laying around to make some spacers, glued them to the middlepanel and used velcro to mount the LED panels to them.
For the connection of the panels I used some cables with servoconnectors on both sides and pinheaders on both the leds as well as on the power distribution boards.
