How to detect beats of a sound. you probably think about a microphone, fourier transform, peak detection, But after real case testing. a v easy sound detector sensor can do the job, because we can just use the volume. I used the sound detector sensor as below. if using the digital output of the sensor. I can only get binary, it will not give a good music visualizer to me, but when I use the analog output of it, it gave me the scale of volume by voltage. this is what my music visualizer is based on. so when I move this project to raspberry pi. I need a ADS1015 to do the job.
The prototype is made with a v budget version of
+ an unofficial Neopixel LED Ring (made trouble to pi)
+ a NODEMCU
+ a digital sound detector (not even a microphone)
(I don't know how to draw the connection, man. here is the photo. sorry for that, I will make it formal asap.)
To join the competition of Visualize it with PI
I modified to
+ raspberry PI Zero
+ same sound detector
+ ADS1015
+ NeoPixel Ring
(Unfortanately, since the NeoPixel Ring I used is too bad quality, it doesn't work properly with the standard LED library rpi_ws281x. )
the hardware in the prototype is not integrated to the lemonade itself. but a LED ring place under the glass bottle. (pretty lame, right? I know. can be anything, but lemonade is ideal diffusion.)
Future Plan,
I need an good quality Neo Ring to make the library works on Pi.
and also if I don't play electronic music which counts lots on rhythm but play some pop music with vocal. you will see the bottle keeps blinking. v not cool, so I want a hardware knob to control the sensitivity, it is necessary if I wanna make the bottle universal fitting, from free jazz to heavy metal.
second thought is replacing the sound detector with a real microphone. then i can have more room on the processing,
third thought is if I can get better LED equipment, I wanna make the visual more playful and dynamic. like particle chasing game or physics bouncing effect but on LED. (so much on my mind, too less got done.)
I also need a clever design, will be good if anyone can give me an direction how to really design a stand-alone bottle music visualizer. where I can not only hide all the component cleverly but also can drink the blinky drink,
So if anyone is interested, yoooooo, of course we can work on it further together.
Aileen Xi
Matt
Curt White
ZaidPirwani
I have done similar project using the Adafruit circuit playground express. It has 10 neopixels on the board and a microphone, light sensor etc.
Using Makecode, I have got it responding to sound quiet smoothly.
