Pickguard off electronics in the pickups are detachable I used breadboard jumper wires cut in half for connectors a usb or IDE cable wouldve been better.
10/02/2018 at 23:26 • 0 commentsPickguard off electronics in the pickups are detachable I used breadboard jumper wires cut in half for connectors a usb or IDE cable wouldve been better.
The headstock was previously broken and I tune up the d string to e# and halfstep everything down
10/02/2018 at 23:24 • 0 commentsOriginally a Washburn Lyon the nut was made out of bamboo by me with a kitchen knife -
I had to use a rotary tool to make an humbucker in the middle I eyeballed it with a marker
10/02/2018 at 23:21 • 1 commentPickguard was
Slanted Pickups do a EQ effect like low pass when using 5way switch
10/02/2018 at 23:19 • 0 comments -
AEC PROTOTYPE ON FACEBOOK
10/02/2018 at 23:17 • 0 comments -
10/02/2018 at 23:15 • 1 comment
