1Ride the Wave
Once you've found a sound you'd like to sample, pump it through an oscilloscope emulator for visualization (I like Soundcard Scope).
LABO treats each waveform it reads as a periodic wave, so your waveform needs to remain roughly unchanged between periods. -
2A Clean Slate
A "blank waveform card" template (.SVG) is provided with Waveform Card Pack 1 (see download section).
Use this to carve out the shape of your chosen wave (Inkscape is my vector graphics editor of choice).![]()
3Carve it Out
Using boolean operations, remove negative space until you're left with a positive "top" to your waveform card.![]()
If you put your mind to it, you can make a lot of different cards.
4To the Third Dimension
Import that SVG and extrude it to a 3D shape! Export it as an STL, slice it up, then print it out!
5Sound Test
What was that noise?
Hunter Irving
