Final_Build_Week 14
12/20/2018 at 06:35 • 0 commentsProgress :
- Finalization of Internal locks, latches and notch.
- Implementation of screws and rubber band for spring action.
- Securing positioning and increasing effectiveness of mechanics.
- Recalculating and rewiring.
- Placing arduino and breadboard.
Progress & Finalization :
- Designing, cutting and applying.
- Finalizing outlook.
Outcome | Final Journal Video:
Final_Build_Week 12 - 13
12/20/2018 at 04:02 • 0 commentsProgress :
- Touch up calculation for finalization of internal mechanics.
- Added components for support in internal mechanics.
- Improvisation and adapting to new trial and errors.
- Tidying up internal notch and latches.
- Cleaning up outer look.
- Securing overall locks and internal mechanics.
Beta test_week11
12/20/2018 at 03:53 • 0 commentsBeta test
FEEDBACKS
- Instruction word too small
- Can't find the return ball place
- Instruction might need indication of number
Production week 10
12/20/2018 at 03:24 • 0 commentsCNC cut the shell of the capsule machine
- the outcome of plywood from CNC doesn't met our expectation
we use wood filling to fill those faulty holes.
-attach every layer together and follow the mechanics of our alpha test
Production Stage_week9
11/22/2018 at 08:42 • 0 comments15 Nov 2018
START TO BUILD !
- Fixing bug and ready files for cnc cut
- We calculate the wrong size again
22 Nov 2018
Working on the base layer -
Prototyping_week8
11/22/2018 at 08:23 • 0 comments1 Nov 2018
Prototyping
- Using cardboard to build out the prototype
Error & mistake faced
- wrong calculation
Prototyping for the buttons and Servos
- Research on the code
- bug fixing
8 Nov 2018
Protoyping- .2
capsule machine mechanics try out
ERROR
- broke wires
- need to find out a way to stable the servo
- calculation problem
- sodering wire
PROTOTYPE OUTCOME
For feedback - too many steps for user
- change a way to release the ball.
- instead of word instruction, use icon would be better
CHANGES ON THE MACHINE
We decide to change the ball release door from
"User take out the ball from the compartment" to
"The ball release itself when user press the start button"
Attempt_4
11/06/2018 at 16:46 • 0 comments25 Oct 2018
Proceed with the design
- capsule machine use a "present box" concept for the design outcome
-Getting Message from others its like a surprise
FLOWCHART
- User have to read thru the instruction shown in-front of the machine to understand how to use it.
- After they read the instruction they are require to press the button at the end of the instruction
- Upon user press the button, a compartment at right-side below of the box will open by a servo, and there is an empty ball inside for user to take it out. There will be a green light LED shines on the ball, until user take the ball out the LED will become red.
- User will take the ball write and message to place in the ball. Then user need to toss it into the machine
- Once the ball has being toss into the machine, a servo will unlock the latch for user to spin the notch.
- In return user get a ball that has written message by other people.
- As instruction stated user need to return the empty ball back to the compartment.
- Once the compartment micro-switch detect the ball has being placed back the LED will return green again.
- And the servo will lock the compartment door.
MECHANICS
Measurement -
Design Concepts
10/22/2018 at 01:51 • 0 commentsInitial Design Concept | 22 Oct 2018
____________________________________
New Design Concepts.
Proposal 3.3
10/18/2018 at 04:53 • 0 commentsDesign Prototype No. 1 | 18 Oct 2018
First Prototype Design: Capsule Machine
Capsule Machine: Outer & Inner (For Flexible Maintenance)
Capsule Machine: Bottom Lock System (For Flexible Maintenance)
Capsule Machine: Logic & Measurements
Capsule Machine: Separate Instruction Box Set
attempt3.2
10/17/2018 at 17:32 • 0 comments- usually the mechanics of a toy capsule machine is operated by coin
- only a round object can push up the "obstacle" that blocks the notch
Solution
- This capsule machine is no longer control by coins
- if the sensor sense someone toss a ball into the machine, another motor will put the "obstacle" latch to let user to spin the notch
Below is the full mechanics concept of this capsule machine
The concept mechanics of the capsule machine
1. Once the sensor sense user toss in a ball, it will open up the latch and let the ball fall in
2.at the same time the notch will be unlock by showing green led
3.the ball holder will lead the capsule ball to the exit point of the machine
