1get materials
4x peizo sensors + breakout boards
1x arduino - preferably leonardo
1x pair slippers
4x wire connectors to make life easier4
2install sensors into shoes
install peizo sensors into the rubber portion making slits to slide the sensors into, connect it up. (make sure to pick a nice spot where the shoes do not bend much.
3wire everything up.
connect the midi inputs to the analog pins of the arduino.
4get midi feedback from serial port.
on arduino leonardo you can create a usb interface to send messages as a device, otherwise console feedback can be used.
We work hard to convey to our audience the transformational power of music. We are grateful that you are travelling with us and are excited to share our music with you. https://www.musicaltouch.sg/post/top-bridal-shoes-for-women
