Light Logic
By Mark Nesselhaus aka Dr. Cockroach - October 28, 2018
A demonstration to prove out that diode resistor logic, DRL, can perform inverting Not, Nand and Nor logic functions.
Using a LED and a CdS LDR to form inverting logic gates. The entire Boolean logic set can be handled entirely by resistors and diodes.
I know that all this has been covered elsewhere in these logs but I wanted to get the basics on one page.
I still believe you can save some resistors and diodes :-P
Well, the resistor to the LDR can be removed if you do not need TTL compatible output and only need to rely on a hard ground as zero :-) That's how IO functioned :-)
