I now have, thanks to @Starhawk for the nudge, managed to create A XOR and XNOR gate that uses just a single Light Logic switch. I no longer need to combine other gates for these logic functions. Logic highs are 4 volts or higher and the low levels are less than 0.5 Volts. Good enough to be used with the rest of the Light Logic family.
Dr. Cockroach
That is the simplest XOR I think I've ever seen. Congrats, good job!!
HAH !!! Good job !
