Feed horn assembly finished! (yay) :)
A project log for Slightly bigger radio telescope
My aim for this project is to create a slightly larger radio telescope, which is able to observe signals on the 21cm hydrogen line
gonalo-nespralGonçalo Nespral • 01/21/2019 at 18:50•0 Comments
Yes I know its been a while but I just haven't been in the mood for building radio telescopes recently. Anyway, a few months ago i order this LNA (*32 dB* Gain), which finally arrived, but I haven't tested it yet. I attached it to my horn antenna which will be used as a feed for the 1.2m dish, which I already have.
I built the feed horn by soldering an HVAC adapter to a baby food can, and drilling a hole in the side where I inserted a 90 degree coaxial F-connector and soldered it in place. The dimensions for this aren't perfect, but hopefully it'll work well enough to be able to receive the hydrogen line.
Anyway, here are some pics:
